  • 2852 Views
paganrj
Lately, when I access the app the some cameras start recording imediately. How can I fix this?
You should open a case with support.
paganrj,
What model device/OS version are you using? Are you sure there is no motion detection causing the recordings and it is simply the action of opening the app that is causing the detection?
I agree with jguerdat, consider opening a case with the  Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
paganrj
James,
Thanks for your reply.
It happens when I access the system through my iphone 5. Not sure about the OS version but I bought the system last March. It is not motion because it happens every time I open the app and only in one or two of the four cameras. I guess I will open a case soon.
Regards,
Rey
