Just received my cameras and I am reading some of the FAQ's to get a better feel for them. I believe I have the latest updates:
There is no longer an auto update toggle. All Arlo software updates are now automatically downloaded and installed so your system is always up-to-date.
Go to Settings --> Base Station Settings --> Auto Update FW <-- toggle it green to turn on and don't forget to SAVE..
No auto update listed on my base station settings.
I don't see anything that says Base Station when I log in on the web. Where might it be?
All Arlo software updates are now automatically downloaded and installed so your system is always up-to-date. No more manual downloading or checking for updates required!
You can find additional information about the update here: New Arlo App: A Quick Guide to New Features
Thanks James! I wondered what happened. 🙂
I do not have
'auto update in my settings
souper,
You may want to put that in the first post or the marked "Solved" post.
