  • 8925 Views
  • 2 Likes
coyadams
Once a camera starts recording other cameras do not record until the other camera stops recording. I have 4 original Arlo cameras and 1 Arlo Q.
That shouldn't be the case...the base can stream a max of 5 at the same time normally.
two things, what time amount are you using?
Are all the cameras armed? ( if so the running man over each cam on the live view screen should be black)
Also is you data thruput speeds above the 1 Mbs? As recommend
manfredz
Hero
Hero
i sometimes have 3 cans recording at same time without issue, sometimes all 4
coyadams
Working now
