Not Recording until reset mode
  • 1 Reply
  • 4040 Views
Electrosynapsis
So, I experienced a wierd issue. I set the device to record with motion and left it on all day. Apparently nothing was recorded nor an alert sent; but it is working now after I took it off the Mode set (a mode that has worked and is the usual mode) and set it to no disarmed and then reset it.
Has anyone experienced this? FYI my other camera system arlo q was working flawlessly the whole day. So it can be ruled out wifi issue.
Has anyone else ran into this quirk?
steve_t
Master Master
When you say "reset it", do you just mean you enabled that mode again? No changes to any rules or anything? I've never come across that but it may be wise to check the rules that relate to that camera in your normal recording mode. Maybe test it again. Is the signal strength OK? The wifi of your Arlo Q is completely separate to the comms between the Arlo camera and its base station. Perhaps it had a weird moment with a firmware update. Who knows. Glad to hear it sounds it's working now though
