Since the update there is no RULES SETTING. without the rules setting you can no longer set video recording times or a host of other things needed to run the cameras!
https://community.netgear.com/t5/Installation/NEW-Browser-software/m-p/1023460#U1023460
( try and keep replies above to stop them all over the place )
looks like you can get to the rules from the modes... click mode you want, click edit , and it opens to all the rules, and there is an edit option for the rules
I have the same problem...What happened to the rules settings....I can not adjust the sensitivity on the cameras!! Someone please,respond
thanks buddy.
Yes, it has disappeared along with the "Preferences" tab in System settings. The community needs to be notifying Netgear Support, in mass, of these shortcomings in order to have them remedied as soon as possible. I had a discussion with Arlo Online chat this morning and they have no clue as to when OR if the issues will be resolved.
The supplied answer is not correct. The rule edit does not let the user set the time for the time frame a camera should follow the rule. Netgear has either purposefully or errantly removed a number of controls that users used to have.
ArloLG wrote:The supplied answer is not correct. The rule edit does not let the user set the time for the time frame a camera should follow the rule. Netgear has either purposefully or errantly removed a number of controls that users used to have.
What exactly are you trying to find....?
all the controlls are still there, just moved around
I am glad to hear that the ability to activate each camera by day and time but I do not see it and find no direction within the settings. Can you tell me "specfically" how to get to this setting.
I have the same problem, cameras are not accessible on my computer. I can see them on my ipod. But, nevertheless, the cameras are worth nothing if you cannot see them. You should be emailing support directly in addition to commenting on the community. Arlo Support needs to be getting a deluge of feedback regarding the negative steps they have implemented.
Janetmarie,
What device/os are you using that is giving you an issue when trying to access modes? Consider trying to access modes using a different device (if you're using a phone try a PC) to further isolate the issue. Please let us know!
						Accessories4
						Activity Zones1
						Amazon Alexa1
						Apple HomeKit2
						Apple TV App9
						Applications mobile et en ligne1
						Apps4
						Arlo Go3
						Arlo Mobile App722
						Arlo Pro36
						Arlo Pro 21
						Arlo Q (Plus)3
						Arlo Smart196
						Arlo Web and Mobile Apps18
						Arlo Wire-Free30
						base station1
						Batteries529
						Before You Buy925
						Can't view cameras live at all1
						Dépannage1
						Détection de mouvements1
						Features1,070
						Fehlerbehebung1
						Firmware Release Notes93
						Google Assistant1
						Hardware1
						home security1
						IFTTT (If This Then That)105
						Installation2,046
						Iphone 14 pro1
						Live view1
						Modes and Rules1
						Motion Detection2
						Object Recognition3
						Online and Mobile Apps983
						Online und mobile Apps1
						Order Not Going Through... help please!1
						Other Discussions1
						Partner Integrations4
						Security1
						Service and Storage14
						Smart Subscription3
						SmartThings71
						Troubleshooting9,083
						Videos233
						Vidéo2
						Warranty & Contracts2
