Base station lost internet access. In trying to troubleshoot, I removed all devices (base station and two wireless cameras) in an attempt to 'start over' from scratch. I rechecked the wiring from the base station to the router and - when I had three green lights (power / internet / cameras), I logged onto Arlo.com, selected "New System Setup" and then selected "Arlo Base Station." The screen then flips to "discovering your device .. please wait" -- but it never finds it. Meanwhile, the cameras will sync to the base station ... it's just trying to get the base station to sync to the website. What am I doing wrong? H E L P !! {:)
Like yourself, I had green lights along the bottom of the base station, and tho the cameras would sync to the base station, the website would not "discover" the base station. So, I stuck a pin in the 'reset' button on the back of the base station to return it to factory settings, then started from scratch. It was a hassle having to create a new profile, but everything is operating properly.
Don't use the new system selection. Just log in and use the Add Device button on the Cameras tab. Add your base and then sync your cameras.
My app showed lost internet connection...I rebooted everything. Also tried new set up, base shows all; cameras synced but neither app nor website sees anything. Website only shows "add device" Honestly, I'm sick of wasting my time on this. All batteries are new and no changes to anything here at the home. Any help you can provide before I lose my mind would be great.
Yup, none of that worked for me. Did the same thing. New account set up, factory reset, the whole nine yards. I'm about done with it. System worked fine, stopped for no reason with no internet interruption on my end and this hassle of reconnecting everything, re-sync, is simply a waste of my time when it doesn't work....Going to a professional system installed by my alarm company and not worry about the batteries, the hassle, this kind of nonsense, etc. No help here from anyone at the company that seems to give a crap. My time is far more valuable than wasting it on this.
OOPS! Sorry .. though I can understand your frustration. My system was working fine, then POOF! Got email this morning that system had lost its internet connection, which was crap because I had access to other websites. Anyway, you're right, this having to rely on the kindness of strangers tp help resolve issues versus the ability to correspond with someone at the company is for the birds! A professional system will probably give you better coverage as well, as my little wireless camera dudes cannot detect activity on the sidewalk some 20' from the front door. A lot of good that is when someone is creeping around your house! Very well cannot say, "Excuse me, would you step into camera range please ?"
Good luck ...{: )
mcctti,
If you're still having trouble getting your system connected, even after performing a factory reset, please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
Hello, this is happening to me as well now that I have moved to a new home. Deleted in order to re-add devices of base station and all cameras. Stuck on Base Station. Tried power cycling, reset with pin, tried unplug all even ethernets, tried different ports, reset with pin pressing sync simultaneously as instructed, accessing/attempting add via both Windows laptop and logged out and in of that, then tried with app, logged out of appp, logged in, unplugged, tried on a different day, stayed up late trying to repeat insanely according to all instructions.  May I contact you as well, James?
Thanks for the reply!! I never used the New Setup option, I have been attempting the add device only, after having removed the base station. Now No devices are listed under "my devices" just an icon of a camera and " add device" button. Which leads to the same situation of not being able to add the base station that is 8 inches away, on the same wifi, and Internet and globe light green. Then only thing that isn't working is after several failures I am prompted to hold in the pin reset button and the sync button at the same time until the lights flash amber but they never do, after any length of time depressing the two. I tried just holding down the reset button for 10 20 and 30 sec but still no amber light flash. I tried doing this also again after powering down and powering up when the solo amber light was on but no green yet, and I could not get all amber lights to flash. I can clearly feel and the reset pin button clicking down with different pin sizes, large paperclip works better than ball point pen. Can you think of what I am doing wrong? I appreciate your time and what suggestions you might have. I'm not sure who to contact now. It does not seem plausible that the reasonably new device which has only sat in a protected space since I got it would be failing at this point.
Ok, thanks I did open a case with a new simpler goal in mind of achieving a reset since I never could not get the amber lights to come on. I pushed the pin in much harder than what is needed to get a click, thinking maybe the contact is actually deeper than the dimple or bubble or whatever seems to depress the surface. The amber lights came on with 10 full seconds (a twelve count for me) of really jamming the paperclip in as hard as possible. Then everything went as described above. I am satisfied and the case may be closed. So if nothing elsee works, there is always brute strength. And I work with tools in my hand s most of the day so I do mean push harder than you think.
						Accessories4
						Activity Zones1
						Amazon Alexa1
						Apple HomeKit2
						Apple TV App9
						Applications mobile et en ligne1
						Apps4
						Arlo Go3
						Arlo Mobile App722
						Arlo Pro36
						Arlo Pro 21
						Arlo Q (Plus)3
						Arlo Smart196
						Arlo Web and Mobile Apps18
						Arlo Wire-Free30
						base station1
						Batteries529
						Before You Buy925
						Can't view cameras live at all1
						Dépannage1
						Détection de mouvements1
						Features1,070
						Fehlerbehebung1
						Firmware Release Notes93
						Google Assistant1
						Hardware1
						home security1
						IFTTT (If This Then That)105
						Installation2,046
						Iphone 14 pro1
						Live view1
						Modes and Rules1
						Motion Detection2
						Object Recognition3
						Online and Mobile Apps983
						Online und mobile Apps1
						Order Not Going Through... help please!1
						Other Discussions1
						Partner Integrations4
						Security1
						Service and Storage14
						Smart Subscription3
						SmartThings71
						Troubleshooting9,083
						Videos233
						Vidéo2
						Warranty & Contracts2
