  • 9 Replies
  • 2052 Views
Rrmer
I just subscribed to Arlo secure. After going through the enhancements and using some of the enhancements, my system has all but lost motion sensitivity. My system vmb3010r2 with 6 cameras (5 vmc3030 h7. 1 vmc3030 h16). I have checked and rechecked all settings and rules. Not sure what to do. Any ideas?
9 REPLIES 9
Have you tried the motion detection test?  https://kb.arlo.com/41/How-do-I-change-the-motion-sensitivity-on-my-Arlo-camera
Rrmer
Yes I have. When in test mode the amber indicator light comes on but only in close proximity 1-3’.
This is with the threshold set to 100%?
Do you have any skins on the cameras?
Might be worth removing/reinserting the batteries.
Also, cleaning the camera face might be useful (just in case there is some dirt blocking the PIR sensors).
Rrmer
I did install fresh batteries and always clean lenses when I replace batteries. Interesting enough, the camera I an having the most difficulty with does have a skin. Never been a fan of skins, however this particular camera is the most weather exposed.
The PIR sensor used for motion detection is distinct from the lens.
Try removing the skin as a test, and see if that changes the symptom.
Rrmer
I removed the skin and cleaned the face of the cameras again. No difference at all. I also noticed at night when in live mode the exterior lights seem to be blinking. I did adjust the flicker but no help.
Rrmer
Made no difference what so ever. Not sure what’s wrong.
Are you seeing this on all your cameras?  Or only some?
Rrmer
Overall system sensitivity reduced. Two cameras it’s basically nonexistent. I did try altering the activity windows to cover the entire field of view which made some different, however doing that killed two fresh sets of batteries in about 6 hours.
