  • 13 Replies
  • 11250 Views
  • 5 In Conversation
Todd-
My system has been working fine for years.
Now all of a sudden I can't see recorded videos (stored on local usb) Hub is VMB4540r2
This occurs either inside my LAN or outside the firewall.
Ive restarted the system, formatted usb drive and reseated it.
Any ideas on how to fix?
Thanks in advance
Todd
13 REPLIES 13
If viewed on a computer are there any videos stored?
Todd-
I can see a couple from about 2 weeks ago.  In addition I pulled the usb stick and had a look at its contents and it has video files from as late as a few minutes ago
I'm assuming you're still on the old user interface (UI) that uses Library to view videos - is that correct? Is the pull-down menu still at the top of the library so you can choose between cloud and local recordings? Have you rebooted the phone and reinstalled the app as well as rebooted the hub?
gneileo
I have been having the same problem for the last week or so.  Videos are getting recorded and stored, but I get the same error about videos not being available.  I've done everything that has been suggested.  Reinstalled the app, reformatted the SD card, rebooted the base station, reseated the card, etc. Nothing works.  Videos are getting recorded.  I can remove the card put it in my laptop and view them.  All devices, including the hub are accessible on the network.  Same setup for years.  Hoping there is something new here.
ShayneS
@gneileo Have you tried setting up your direct storage access again via this article? https://kb.arlo.com/000062997/What-is-Direct-Storage-Access-and-how-do-I-use-it-for-Arlo-video-recor...
gneileo
Yes, this was already configured and working for years and has not changed.  Videos are getting recorded, they just are not longer accessible via the app.
ShayneS
@gneileo
Have you checked for a router firmware update? Did you make any changes to your network?
May I ask which troubleshooting steps you have done so far? I don't want to suggest anything you have previously performed.
Have you reserved an ip address for the base station in your router?
If you didn't do that, then it's possible that the router has assigned it a different address.  That can result in the router forwarding to the wrong device (or no device at all).
gneileo
I've tried everything suggested on this board and sometimes multiple time.  As noted in one of my earlier posts
"Reinstalled the app, reformatted the SD card, rebooted the base station, reseated the card, etc."
gneileo
Yes, it has a static IP assigned and reserved on the router.
ShayneS
Hi @gneileo
Is it possible to try a different SD card?
gneileo
I don't have another one that size.  I'd have to get one to try that, but I don't think that is the problem.  Video is getting recorded on it.  I can pull it out of the hub, stick it in my laptop and view the videos.
ShayneS
@gneileo Understood, let me look in to this for you first. I'll report back as soon as possible.
