  • 35 Replies
  • 5052 Views
KachinaShadow
Prodigy
Prodigy
I just replaced my 1st generation wired Video Doorbell with the 2nd generation...connection is through the VMB5000 hub.
Resolution is set to 1944x1944, and everything looks great except live streaming on the web portal (which actually makes 480p SD video look good). Playback of recordings on the app & web portal, live streaming via the app and the still images on the Dashboard and the Devices pages all look great. I tried switching to 1536x1536 and 1080x1080 and it made no difference.
Note that the gen 2 is located in the same location as the gen 1, which had an excellent image when live streaming.
1st pic (below) shows live streaming the Doorbell and Front cams simultaneously...2nd pic shows the still images for comparison.
35 REPLIES 35
BrookeN
I fix is currently in the works, I apologize I do not have an exact ETA as of yet.
KachinaShadow
Prodigy
Prodigy
@BrookeN
I sure would have liked to see if this update would actually fix my issue, but it seems that the latest issue is with the update itself 🙄
BrookeN
Does that happen if you try to update from the app?
KachinaShadow
Prodigy
Prodigy
@BrookeN
Good thought, but when I went to check it looks like it updated itself overnight 🙂
Unfortunately, it didn't change the extremely bad live streaming image (pic below). Earlier (back in December) you had sent it to Jeff so, since it's been 8 months, I'm wondering if I'm ever going to see the 2K live stream image that was the whole idea behind upgrading to the 2nd generation doorbell. Note that the live stream on the app remains perfect...the issue is only on the web portal.
KachinaShadow
Prodigy
Prodigy
@BrookeN
Thought I'd take a look at just how this supposed 2K doorbell camera looks in "full screen" on the app and figured someone might be interested in just how different and distorted the image is. 1st image is done from the "Dashboard" and 2nd is done from the "Devices" screen...both are on the web portal. Of course, the smaller live stream "preview" image still looks bad, as shown previously in this thread.
It's been 9 months since this was reported and there's still a horrible image in live view...any idea of when this might be fixed?
KachinaShadow
Prodigy
Prodigy
Hit "post" prior to attaching photo...would not allow adding photo in "edit" mode so I deleted and will post again.
KachinaShadow
Prodigy
Prodigy
 @BrookeN
After 10 months, since you first sent this to Jeff, I couldn't stand looking at the bad live view of the doorbell camera (only on the web portal) so I added a Wyze V-4 camera (2.5K), triggered by a standalone motion sensor, processed by the Alexa app and sent almost instantly to my Echo Show 5 & 8 along with alerting my phone so that I can also view it there.
The image is what I had expected from the Arlo 2nd generation 2K Video Doorbell, so I thought I'd share it so that Jeff or the developers could see the actual comparison between the two.
I'm really hoping this will be resolved soon.
Edinburgh_lad1
@KachinaShadow
You'll save yourself a lot of time and effort by just switching over to a different system altogether.
KachinaShadow
Prodigy
Prodigy
@Edinburgh_lad1
I suppose...but there's nothing I like more than a challenge 😎
KachinaShadow
Prodigy
Prodigy
@BrookeN
Hi Brooke,
Were you able to share the image & remarks, from Message 32, with Jeff and the developers?
BrookeN
I was, they are investigating the behavior you are seeing.
