  • 30 Replies
  • 12124 Views
  • 7 Likes
  • 14 In Conversation
domone
My base station is stuck on firmware 1.21.1.0_1431_9611cf3 and when you go into the settings to check the firmware it says "no updates available."  According to the firmware releases, I should have 1.23.0.0_1520_b69eb19 available to me but it's not. I had to factory reset my base station in order for it to see any of the cameras I wanted to link locally, not sure if that has anything to do with it.
https://community.arlo.com/t5/Firmware-Release-Notes/Arlo-Firmware-Release-Table/td-p/1920885
30 REPLIES 30
PissedOffArlo
I’m also still stuck on 1.21…. 😢
BrookeN
This update should be available, can you please check the latest firmware?
superyin
Both of my Ultra 2 cam still stuck in 1.070.52.1, can you push update to both of my cam? Thanks.
BrookeN
Can you send a screenshot of what you are seeing under get updates?
superyin
Hi, the capture contains serial no. so I sent as PM please check
BrookeN
Were you able to update the basestation?
