VMB3000 unable to connect to Arlo Secure app
  • 12 Replies
  • 1871 Views
Steve338
After much research, I have concluded that the Arlo Secure app does not support my old base station (VMB3000).  This is really unbelievable and unacceptable!!  Arlo has outgrown me and I have outgrown Arlo.  There are many cheaper and more versatile options available.
Arlo, if I am wrong about any of this, please reply and prove me wrong.
12 REPLIES 12
It should work.
Can you explain the symptoms you are seeing? Did you remove the base from your account, and are now trying to reconnect it?
Steve338
I have done every conceivable thing described in the documentation for 3 days in a row with no luck.
Or is this somethine else?
Steve338
As far as I know my base was never successfully connected to my account. Under devices in the app, I see nothing—just blank.
So this is a new install?
Did you purchase this base used?
Steve338
I purchased it new in 2016/2017 and used it briefly in my former residence and with a different WiFi network.  It  worked well as advertised.  Subsequently, I stored it in a closet and am now trying to set it up for my current residence with a different WiFi network.  So, the base and 3 cameras sat in the original box for 7+ years.
If the cameras and base were left in the old account, then you would not be able to add them to a new account.  Is that possibly what happened?
Steve338
Yes, that’s possible. How do I undo the old account, since I don’t see anything in the app?
You would need to log in using the original account's credentials. If you can't remember them, you could try to ask for help from the support team but I don't know how they would  be able to help. @JamesC , @ShayneS , @BrookeN any possibility of this?
BrookeN
Support may be able to. look into this with the device serial number. However I am not certain. I have created a ticket regarding the trouble you are having. Someone will be reaching out to you shortly.
Steve338
My base serial number is  and it’s model VMB3000
BrookeN
Thank you for providing that information. Support will be reaching out to you. I did remove the serial number from the post for security reasons.
