I would be very appreciative if someone can direct me, I have the cameras not even sure what model they came with the VMB3000. There is no charger and I need to know WHICH exact model of charger I need to get can someone kindly advise or direct with a link or product SKU # . Tha k you so much for your help in advance.
@zophi wrote:Can I use the 1500ma amazon brand rechargeable batteries or is that a not a good idea?
Arlo did a fair amount of testing before they settled on Tenergy some years ago. But it's been quite a while. So you can certainly try other brands.
Open the housing of one of the cameras, and remove the battery. There's a label inside that will tell you the camera model.
Hi I looked it says - vmc3030 it has the Panasonic CR123A battery and model number battery cr17345 i need to charge these?
No, there are not rechargable.
Tenergy does make some rechargable batteries for the camera which are worth considering.
