  • 5 Replies
  • 2674 Views
zophi
I would be very appreciative if someone can direct me, I have the cameras not even sure what model they came with the VMB3000. There is no charger and I need to know WHICH exact model of charger I need to get can someone kindly advise or direct with a link or product SKU # . Tha k you so much for your help in advance.
@zophi wrote:
Can I use the 1500ma amazon brand rechargeable batteries or is that a not a good idea?
Arlo did a fair amount of testing before they settled on Tenergy some years ago.  But it's been quite a while.  So you can certainly try other brands.
5 REPLIES 5
Open the housing of one of the cameras, and remove the battery.  There's a label inside that will tell you the camera model.
zophi
Hi I looked it says - vmc3030 it has the Panasonic CR123A battery and model number battery cr17345 i need to charge these?
No, there are not rechargable.
Tenergy does make some rechargable batteries for the camera which are worth considering.
zophi
Thank you so much for the link and direction
