My current setup is with the base unit being plugged directly into the router I have.
However I would like to move the Arlo base station into a more central position of the house. Has anybody got any advice on how to do this?
I don't want to run a long lan cable between the different rooms and have been looking at a Devolo dLAN powerline adapter. If I understand correctly using this device one part is connected to the router and another point is connected to the device using a lan cable.
Do you think this would work?
Use of a WiFi or powerline extender should work fine as long as the extender has an Ethernet portfor the base. Several folks have done this as reported here.
Thanks for your help, yes the adapter I'm looking at has the ethernet port. Have already bought one wifi extender that was not suitable, so was looking for guidence before purchasing another.
