Hi there! I've been using my arlo setup for a couple of years, without much fuss. I have to Arlo wireless cameras and one Arlo pro camera. After not using my set for a while I started last week using it again. I encounterd a problem i am unable to fix, perhaps anyone revognizes this problem and has a solution?
I used to download videos from the arlo app on my phone (oneplus6). But now, when I push the download button, the video doesn't seem to be downloading. I checked all the obvious and less obvious folders. I usually get a 'downloading' icon in my taskbar. This also does not appear. Therefore, i suspect no downlading is taking place. I can however download on my mac, so its either something in the new arlo-app or in my phone settings that is causing this. Anyone has similar issues or thoughts? Thanks!
I download videos occasionally on my Android devices with no issues. I'd start by 1) checking app permissions to verify that access to files and folders is allowed, 2) rebooting the phone and 3) reinstalling the app, making sure all permissions are granted.
Thank you, I'll try that!
Hi jguerdat,
I tried your suggestions, unfortunatly that had no effect, download still doesn't seem to start.
WHat phone, OS and app versions?
oneplus6, android 10.3.0, app v2.12.3_7015
Same problem here. Cannot download or view videos on the Arlo cloud any more. I’m using iOS on an iPad Pro and an iPhone SE, both App Version 2.12.2 (2.1.2020). App permissions granted. My Arlo setup is also some years old.
Seems to be a problem on the Arlo server for serveral weeks now. Very disappointing.
Hi DouglasBeyki,
Are you experiencing this issue when you're downloading through WiFi and/or cellular data?
Hey PlutoX,
Have you tried to uninstalling the Arlo app, rebooting your iOS devices, and reinstalling the app to see if that helps?
Thanks, Jessica, for your reply.
I’ve rebooted my iPad without effect. But my problem description was not very precise. I was not able to download or to view a video within the app. The busy indicator was spinning all the time so that I always abort the view/download.
So I was patient and after minutes (!) the video starts to play. Typically the video starts to play after seconds. I’ve tried to view different video through wifi and cellular. No difference. It always took minutes until its starts to play.
I also checked my internet connection and downloaded different files from different location and I got always more than 50 Mbit/s with my wifi.
Does Arlo probably have a problem with their server connection or at least with the connection to my isp? I live in Germany, so the data has a long way to go 😉
You can check the System Status here to see if we had any server issue: Arlo System Status
If you still have problems viewing your library playback videos and/or unable to download, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Hi JessicaP
Cant't download while using wifi (tried different networks) and not while using cellular.
I've been having this issues for some 14 days, I haven't checked everyday, but it doesn't seem to be a server issue.
Thanks for your reply, i will contact support
I can't share it either. None of the options, Share, Download, Delete. work. I've tried in the App on Android and Windows PC.
Download and Delete certainly work in the web client for me (on a Windows PC). What browser are you using?
Firefox and Chrome on 2 different PC's
The process is to go into the library, and click on the three dots under a file. You'll see delete, download, etc at the bottom of the page. Click on one (for instance download) and it works as expected on my PC (using Chrome).
What happens when you do this?
Installed the most recent version of thd app and checked the app's rights.
