  • 15 Replies
  • 4016 Views
KachinaShadow
Prodigy
Prodigy
When trying to add a routine, in all modes on the web portal, the "next" is grayed out.
ShayneS
@KachinaShadow Thanks for the update again. this should now be fixed as well.
15 REPLIES 15
ShayneS
@KachinaShadow
Have you tried clearing your cache?
Which browser is this occurring with? can you provide the exact steps to replicate the symptom. I tested on a Safari browser and can't replicate this messaging.
KachinaShadow
Prodigy
Prodigy
@ShayneS
Edge browser...clearing cache didn't help
Go to "Routines"
Pick any Mode
Under "Device Rules" select any device
Where it says "Then do this" click on the plus sign in the circle
Then the "Add an Action" popup appears, and you'll see that the "Next" is grayed out so you're unable to add an action that will run when triggered
@KachinaShadow wrote:
@ShayneS
Go to "Routines"
Pick any Mode
FWIW, I am also seeing this with Edge.  The usual list with radio buttons (record a video, take a snapshot, turn on a light, activate siren, customize device) can't be displayed because "Next" is grayed out.  It does work in my app.
ShayneS
@KachinaShadow I reported this as well. Thanks for letting me know.
ShayneS
I was able to press the next option on Chrome and safari today. Are you still experiencing this symptom?
"Next" is still grayed out for me using Edge.
KachinaShadow
Prodigy
Prodigy
@ShayneS @StephenB
Same here...still grayed out
ShayneS
With further testing, this wasn't reproducible on edge with version "141.0.3537.92 (Official build) (64-bit)"
Can you verify if you have this version? if not, can you update to this version and test again.
I just updated, and am running  141.0.3537.99 (Official build) (64-bit).  Same problem - I select a camera (I tried a Pro and the Ultra), then press the + sign next to "then do this".  The "add an action" list in the pop-up is empty, and the "Next" is grayed out.  This happens every time.
KachinaShadow
Prodigy
Prodigy
@ShayneS
I'm still on version "141.0.3537.92 (Official build) (64-bit)" and still have the same issues as @StephenB
ShayneS
Noted, I will inform the dev team.
ShayneS
@StephenB is it possible to provide a HAR log while replicating?
Yes.  Send me a PM with details on where you want it emailed.
KachinaShadow
Prodigy
Prodigy
@ShayneS
Seems to be working now 😁
ShayneS
