  • 20 Replies
  • 55040 Views
  • 10 Likes
  • 11 In Conversation
Fun-boy
Is it possible to turn the infrared off ?
I have place it inside my patio widow it has a bright spot on my screen.
Does it still sense motion through the glass ?
20 REPLIES 20
No it is not possible to turn off th IR ilumination at this time... So as you found, when placing the camera inside the window, you get reflection of the IR which effects the camera view.
Also, the IR sense for motion will not work through the glass.
The camera is waterproof and made to be placed outdoors to overcome these problems.
Fun-boy
Thanks Tom
Yes we know it can be installed out doors.
It can also be stolen in seconds.
Not trying to make fun... but one of my mounts is under the roof eve.  If you can get it , go ahead.
It's prob 10feet up and I have to drag out a ladder when I use it.
R_Lowe
Luminary
Luminary
C'MON Tom; that's a no-go.  You've been here long enough know that SEVEN feet is optimal!   😉
But seriously (and as a general comment), Arlo being wireless and waterproof for outside use is both a Godsend AND a curse.  I guess at some point we just have to hope honest people will remain honest.  And making them ladder-worthy at 7-10 feet is certainly a good way to encourage that folks remain that way.
snip.... 7-10 feet is certainly a good way to encourage that folks remain that way.
Thats' why i wrapped one camera up in camo cloth for use in the bushes.  🙂
R_Lowe
Luminary
Luminary
I was thinking a very similar thing for at least my nature-situated camera (to come shortly).  I want it to blend as opposed to drawing attention to it.
In a similar vein -- so hopefully I don't have to start a new post -- may I ask if it is true that a light on the camera comes on when it's recording?  I'm concerned about catching somebody at night and am not enamored with the thought that they might see the camera's light like a beacon and steal or destroy it.  If there IS a light, would a simple piece of black electrical tape do the trick...?
4vrnvr
No recording light, just the IR light.
R_Lowe
Luminary
Luminary
Is the IR light [on the Arlo] of sufficient brightness that it could be seen by someone at night?   Make that "detected" by someone at night.
4vrnvr
Its not bright but in darkness could be spotted if someone is looking around. If you place the camera up at that 7 to 10 foot height they could miss it.
4vrnvr
Also the IR isn't on until recording starts.
Yes, if you create a "mask" for the camera face with elec tape ( to cover the IR leds ), it will block the light.  The camera will still convert over to a B/W mode when dark but have no illumination unless you provide external light.
Yes, the IR leds put out at 850nm. In real talk, they put out a dim red glow when on.  The glow is visable but it's not like turning on a flashlight.
If not in your line of sight when it kicks on, you wouldn't notice.
BTW, the external flood lights that Vuezone used work great with these as additional lighting. ( flood had a longer range and fov, but do require being plugged in )
R_Lowe
Luminary
Luminary
Thanks all (re my side questions); that seems to cover things.
MIke12
This is a bad design ... There should absolutely, be an option to disable the IR illumination regardless if the camera is to be placed out doors or not. For now 2 options ...
1. Place tape on where the IR LEDs are located (easy)
2. Open camera and disconnect IR LED's (this is difficult to do)
To designers... In the Settings page of the camera, there should be an option to disable IR Illumination. (we know that this requires circuitry and/or firmware modification
Smiley Happy
KristynM
Hello,
The development team is always looking for new ideas to improve our Arlo system.
You should drop your idea about having the addition of Turning off the Infrared/Night Vision inside the Arlo Idea Exchange
Thank you.
Regards,
KristynM
Arlo Support Team
NekkedRunner
Nobody with eyes could miss the IR, even at max height.
Doubt there are many blind burglars so don't expect the cams to not be seen, especially at night when the IR leds are like an banner saying, "Here I Am".  lol
Best you can do is keep the cam out of easy reach.
If you haven't seen yet... the option to turn off the IR is now available for Arlo cams... if you have enough normal lighting like floods
In my experience tho, most of the time Overt cameras are better than Covert...
calebsw
TomMac, did this feature get removed between the time you posted and today?  Or did you just mean there's a way to disable night vision mode? Because I can only see how to disable night vision mode, which is the only way to disable the IR leds.  Just wondering where this feature should be.  I'd like to disable the IR leds without disabling nv mode.  Otherwise, i suppose electrical tape would be an acceptable solution, as some other guys have mentioned here
The night vision switch is just for the IR illuminators, not the ability to use the camera at night.
BobInPhx
This discussion of camera settings is perpexing.  I just bought this system, applied all updates, and the only camera settings I see on the app and the website are:
  Camera Name: a Setting - which doesn't seem to sync with the web site and all app users
  Camera On/Off: a Setting of dubious usefulness
  Battery: Not a setting
  Connection: Not a setting
  Device Info: Not a setting
  Remove Device: OK, perhaps you can classify this as a seting.
manfredz
Hero
Hero
you need to explore more
under each cams settings you go into video settings for such things as IR on/off, picture inversion and video quality
go into modes and the camera and, among other things you can set the sensitivity and recording lemgth
explore, read and learn.
