How do I turn off Touch Id on the iPhone X - Several FAQ's list going to Settings>Profile but there is nothing there about turning off Touch Id.
Thoughts?
Jeff
I'd reinstall the app before doing anything else.
JK2015,
Within Settings > Profile you should see a "Touch ID is now available" prompt. From there, you can disable Touch ID by toggling the slider to the left.
Hi Thanks for the update - however, there is still nothing other than my email address in the Profile section of the app.
No slider - no nuttin'
JK2015,
I've tested this on an iPhone X and was able to see the toggle for Touch ID. Have you enabled this feature on your device? Use Touch ID on iPhone and iPad
Yes, I've was using touch id with my old iPhone. I just upgraded to an iPhone X. Next to my email address on the main log-in screen it says "log in with Touch ID." Since that is still turned on, it won't save the password so I have to reenter it everytime I want to see what's going on. There is no "enable touch-id" in the iPhone X setting - since the iPhone X doesn't have that capability anymore. I've seen the FAQ's that recomend the Settings>Profile> answer but when I pull up the Profile the only thing on the screen is my email address.
JK
Probably should have done that first - it worked...
JK
