Trying to figure out how to turn off the camera. Instructions say to go settings-my devices-chose my camera and touch the on/off button. I dont have such an option. When I select my camera the following is on the screen. Name , video settings, position mode, motion detection test, device info. Yes I am new to Arlo.
That is the normal way ....
But 1) ...your not saving any battery power by turning off the camera that way ...it's more for privacy if you share the ability for others to view that cam
2) I wonder if you don't see it due to your system new with an older SW version on it?
IRS,
Firmware updates will take place automatically overnight. You can check your camera firmware by logging into your Arlo account and navigating to Settings > My Devices > select the desired camera > scroll to the bottom of the screen.
Current Arlo camera firmware as of 9/13/2016: 1.2.4941
