The camera failed to connect. Try again. Message keeps appearing
Hoping for a little help. My cameras were all working great until yesterday.
Everytime I log on to the app I am getting a "camera failed to connect. Try again" on the screen. This is happening with all of the cameras. Any ideas of what this could be. I tried resyncing the cameras but that has not seemed to help.
Thanks!
Are all three green led's on the Base lit? If so, try logging out of Arlo, then log back in. Hope that helps.
Hi,
I am not at home to look at the base but I tried to restart it from my phone. I did try logging out and also restarting my phone but nothing has worked.
Thanks for the suggestions.
I am experiencing the same problem. Syncing or signing in & out is no help. Support information suggests a "Restart" through the device settings. Unfortunately, that option does NOT appear on the menu!
Any additional suggestions would be appreciated. Thanks!
Would you believe I went through a whole bunch of nonsense to learn that the only "fix" was to replace the batteries! ALL OF THEM!!
Sad thing; I had just replaced them for one of the cameras.
Here is what I did: 1) Shut down/restarted the modem and the router. 2) Found the "Restart" button on the BASE device. 3) Started to sync
the cameras - no results. 4) Replace the batteries.
You might want to start with number 4 first. I couldn't believe that ALL the batteries went out at the same time, either.
If the cameras have lost connection to the base, the batteries will relatively rapidly deplete since they're constantly trying to reconnect. I don't know exactly how fast they'll deplete but it's much faster than just sitting there. SInce the batteries were already in use with unknown levels, it's quite possible that it wouldn't take long to drain to nothing which would explain needing to replace all batteries at the same time.
Now, that makes sense. Thank you!
I continue to have problems with this system. After months I finally fixed it, but lasted for a week. Now it says FAILED TO CONNECT. Have tried the following -
1. replace batteries
2. Resync cameras
3. Shut down app on phone and restart
4. Shut down app on computer and restart
5. Scream lol
Not sure what else to do - but this is crazy!
THX
MonicaDuMont,
It sounds like the signal strength between the camera and the base could be weak or being interrupted.
How far from the base is the camera? Are there any other nearby wireless devices that could be interfering with the signal?
I have no clue what to try next. Can someone please assist!
I have the cameras no more then 30 feet away from the base station.
I cannot spend this much time on these cameras - any suggestion. Have worked less then 1/4 of the time!
M
30 feet can be too far depending on various things that impede the signal. Try moving one or more close to the base to see if they still do the same thing. When the issue pops up, what are the LEDs on the base showing, including color? Open a case with support using the Contact Support link at the bottom here.
My unit is 5 ft from the wireless router and I cannot connect. My other unit is 30 ft away and is currently streaming. Sometimes it's reversed. There is something seriously wrong with their service. I just bought an Arlo Q Plus thinking that the hardwired line would be more stable but sadly no. It's craps out just the same.
I call support and their solution is for me to change my password to arlo123 so they login -- UNACCEPTABLE privacy violation! They don't have to other tools to diagnose connections problems?!? FYI remove and re-adding the devices is a waste of time.
One thing I notice Arlo uses AWS but for some reason I get routed to the EU-WEST instance even though I'm in the US on the east coast -- that could explain my high latency.
Think this is gonna have to be a return.
samman,
Is the issue intermittent or does it always occur every time you try to live stream? Do you see the same behavior when using the web client and mobile app?
Intermittent.
Both web and app.
samman,
You might try swapping locations with the working camera to see if the behavior follows the camera or the location.
Rhpoch,
It can sometimes take some trial and error to find optimal conditions for your Arlo system.
Take a look at the tips in this article to be sure your cameras are positioned for best performance: How do I optimize motion detection for my Arlo Wire-Free, Arlo Pro Wire-Free, Arlo Pro 2 Wire-Free, ...
I have same infuriating issue where after live streaming the camera will go into some mode where you get the camera failed to connect message and the only way to fix it is to unplug the camera and plug it back in. What a piece of junk!
Try power cycling the base. Verify the firmware is up to date. If needed, try removing the camera from Settings, My Devices and resync.
I'm having the same stupid issue!! they worked 2 weeks great now always say cannot connect and I need them the most right now due to some issues!!
Trying replacing the cat5 cable ,found supplied cord with mine had a bad spot and limited signal strength even though directly connected.
My step brother is a computor engineer and was able to find and resolve this,after arlo support failed to recommend this as a possible cause.(no one is perfect and not bashing arlo) please do not take the statment as a rant.
The cable is folded to point of crimping from being packaged.
I am also very sorry for this worrisome purchase! Seeing this product in a lot of stores and I just want to put up a junk sign!
