Tenergy offers Arlo Approved (?) RCR123A rechargable battery for VMC3030? Any success?
Tenergy are offering Arlo Approved (?) RCR123A rechargeable batteries for use with VMC3030 cameras. These are nominal 3.7 Volt rather than the 3 Volt RCR123 batteries. (Probably over 4 Volt when fully charged). Is anyone using these successfully with the VMC3000 range of cameras?
YES...
The Arlo HD camera's power scale was adjusted way back to allow for the different batteries.
A 123 cell when new is really 3.2 volts and the drop out for the camera is about 2.75v ( when needed to be replaced )
A rechargeable is 3.7v and when off charge are 4.2 v ( will drop to about 4.1 after short time ).... there is no issue using these cells in the Arlo HD and I run a few with the Tenergy cells.
The major diff you will see is that the capacity of the battery is only half of a non-rechargeable , SO the battery will last about 1/2 the time... not an issue since you recharge them. ( any 3.7 v rechargeable can not physically fit more chems in the size cell to produce more power so any rated higher than about 750mah are false claims )
The tenergy cells are good and also safe which is very important... some china cells in the past have cause over heating issues as they don't have over-charge/over drain protection like the tenergy's
PS, some of the 3.2 or 3.6 v cells don't work well , esp ( IIRC ) the lifepo4 type was one of them
BTW, there are SOME other good quality 123 cells that also have protection built in ( check the old threads ) but the Tenergy is the only one approved b Arlo
Thanks, I`ll order some to try.
