Camera blue sync light continues to flash but camera never sync's. Light after about 5 minutes goes out.
Funny, but the next morning I thought I would try it one more time before sending it back. BINGO, it worked immediately! Very easy camera set up process so I do not think I did anything wrong the first go around. Thanks for your support.
Make sure you're only pressing the base station sync button briefly - don't hold it. Any luck?
Yes, This is an add on camera. The first 4 cameras were easily inslalled. I have another add on and it is doing the same thing. Blue light flashes continually, then turns amber and then off.
Is there a reason add on cameras that are bought with another base station will not sync with original base station?
Waimone,
Consider rebooting your base station (using the on-off button) and try again. Please let us know if you're still experiencing this behavior.
Waimone,
Great news! I am glad to hear you had a good experience setting up the system (aside from this one hiccup).
