  • 5 Replies
  • 6312 Views
  • 5 Likes
HP_4
Sync button on model: VMS3430 not operable.  No light displayed after pressing sync button for 2 seconds.  Thank you!
That may be holding the button to long... ( it puts the base into a different mode )
Try and just do a quick press on the base's sync button and then push the camera's button
5 REPLIES 5
HP_4
TomMac,
Thank you for your response.  I'm up and running.
Rbaitfish
This didn't solve my install issue, still no lights on router and goes to Amber on camera in 5 seconds...
No lights at all on the base?  That's a problem of either bad power supply or base.  Return the system to the store and swap for a new one.
As mentioned, if no lights at all, there's more than syncing problems.
The LEDS from left are, POWER - INTERNET - CAMERAS.
If the first two aren't Green, you'l never be able to get the system working. After the first two, then syncing a camera turns the third LED green.
So.... what color are the LEDS on your base?
