Just how waterproof are they?
  • 4 Replies
  • 26068 Views
  • 13 Likes
  • 5 In Conversation
Moneybrawler
Can these cameras be place uncovered and survive in the rain?
Dinerve
Hey there,
I currently live in Ireland, it rains most of the time and went through a couple of severe storms, no issues whatsoever, got 2 cameras wall mounted outside and they've been working perfectly fine.
I read somehwere they have an IPX5 rating, which provides enough protection for the below as per the wiki page here:
5
Water jetsWater projected by a nozzle (6.3 mm) against enclosure from any direction shall have no harmful effects.Test duration: 1 minute per square meter for at least 3 minutes
Water volume: 12.5 litres per minute
Pressure: 30 kPa at distance of 3 m
hokeysmoke
Virtuoso
Virtuoso
I've had them for nearly two years in rainy Oregon and have had no problems.  I have five cameras outdoors without any protection.  Make sure you bring the cameras indoors to dry out when you change the batteries, just like any waterproof camera.
As an extra measure, a small wipe of silicon grease on the sealing oring  helps make the cam water tight
buton
this is great to know they have survied. I have them outside but they will not get that wet. is good to know you can put it anyware
