@anolte01 wrote:
Yes USB C - I want to use my Arlo solar panel with another product
No idea whether they will work with anything else.
The current panels are
- https://www.arlo.com/en-us/accessories/VMA7600-10000S.html
- https://www.arlo.com/en-us/accessories/VMA7600B-10000S.html
The only difference between them is the color. Both have USB-C connectors.
There are several older panels. The only old one with a USB-C connector is the VMA6600. That is quite a bit smaller than the 7600, so I think it will provide a lot less power.
The others either used microUSB or used the proprietary magnetic connector.
@anolte01 wrote:
Is the basic Arlo Solar panel USB3?
What model (no idea what you mean by "basic")?
The panels just deliver power.
Did you mean USB-C????
