  • 2023 Views
anolte01
Is the basic Arlo Solar panel USB3?
@anolte01 wrote:
Yes USB C - I want to use my Arlo solar panel with another product
No idea whether they will work with anything else.
The current panels are
The only difference between them is the color.  Both have USB-C connectors.
There are several older panels.  The only old one with a USB-C connector is the VMA6600.  That is quite a bit smaller than the 7600, so I think it will provide a lot less power.
The others either used microUSB or used the proprietary magnetic connector.
What model (no idea what you mean by "basic")?
The panels just deliver power.
Did you mean USB-C????
anolte01
