  • 32 Replies
  • 3191 Views
MC3
Hi, I need a setup code to pair my base station with HomeKit.  It is the VMB5000
From what im reading I think I need a token reset?
32 REPLIES 32
BrookeN
See if you are able to see an accessory that you can remove:
Go to the Home App.
Long-press the accessory, select Settings, and choose Remove Accessory.
MC3
It does not show up in HomeKit for me to remove.  I am unable to get past the screen where I have to scan the setup code.
BrookeN
If all the steps I have provided were done, I do not have any other steps to provide. You should with those steps be able to set up without a code.
MC3
What are the next steps then if my device is defective?
BrookeN
It wouldn't be the device that is defective. It could be something to do with the Apple homekit app itself.
MC3
What makes you so certain of that?
I have added my Hue bulbs to homekit, my thermostat, my HomePod, my Apple TVs with no issue.
The only thing I cannot add is the Arlo basestation.
In addition, I have tried adding on both of my iPhones.
MC3
Following up on this.
BrookeN
