Setup Code for HomeKit VMB5000
  • 32 Replies
  • 3151 Views
MC3
Hi, I need a setup code to pair my base station with HomeKit.  It is the VMB5000
From what im reading I think I need a token reset?
BrookeN
32 REPLIES 32
There is no setup code - you use the "no setup code" instructions here:
If that fails, then you likely do need a token reset.
MC3
If I press continue through all of that I get stuck with either having to scan a setup code with my camera or enter one.
BrookeN
I reset the token, follow the steps within the link to set up without a code:
https://kb.arlo.com/000062279/How-do-I-connect-my-Arlo-device-to-Apple-Home
MC3
Now it is stuck on "Discovering your device"
Before the base station showed up, now it no longer does.
BrookeN
I was going to reset the base station again, however I cannot see the basestation on the account. Did you reset it?
MC3
It showed up after about five minutes as an unverified accessory so I followed the online instructions for that.
MC3
Ok, now I am in the same position I was when I started.  I followed the instructions with an unverified accessory and removed it and added it back.
Now when I attempt to add the base station it is requiring a setup code. When I click continue, the same screen shows up and prompts me to scan a code.
BrookeN
I reset the token again, however if it does not work you may need to do a reset of the basestation. Please keep in mind if you reset it, then you will have to add the cameras again.
MC3
I removed the base station according to the unverified accessory instructions.
I had to add all the cameras back when I added the base station again. I just did that.
it is still requiring that I scan a setup code.
why Would I reset it again if I just reset it?
BrookeN
@MC3 were you able to get the homekit set up?
MC3
No I was not. And I’m out of town until next week.
can I message back here when I’m back home?
BrookeN
Yes of course. Have a great time.
BrookeN
@MC3 were you able to set up the Homekit?
MC3
I have not been able to get it to work.  I still requires a code for finishing.
The screen I cannot get past is a scan a setup code screen.
BrookeN
The next steps would be to reset the base station. Please keep in mind that you would need to add the cameras back onto the account. If you decide to do that, please let me know and I will reset the token again.
MC3
I will do that.  Do you need to reset the token before I reset the base station or after?
What should be the specific steps?
BrookeN
I reset the token.
Reset the basestation
Add the cameras back on
And then do the steps to set up without a code that are in this link;
https://kb.arlo.com/000063184
MC3
So I will need to add all the cameras back before adding to HomeKit?
Is it possible to attempt to add the base station to HomeKit before the cameras? It takes some time to add all the cameras back and I have tried this already by reseting the base station, adding cameras, then attempting to add to HomeKit to no avail once before.
BrookeN
You can add the base station to homekit and then add the cameras if you want to do it that way.
MC3
ok, I have done a reset, removed the device, and also deleted the app.
When I first tried to add the device it was an "uncertified accessory."
Now it is asking me for the same thing--a setup code.
It tell me to locate the QR code, I have no option other than to click continue.
It tells me to scan or hold phone near accessory or click "more options."  I click more options, select the basestation.
It then tells me to enter the code found on the accessory box or instructions or to use the camera.  I click continue as I have no code to enter nor nothing to scan. Then it auto opens up a camera to scan for a QR code.
I have not been able to get past this step no matter what,
MC3
I thought I might have had it working when I put in the 23815 number, but it thinks and says unable to add device.
MC3
 when I try the 23815 number it tried to connect but then says it times out.  if I click continue without code I get this message.
Did you remove the device from your account and then re-add it?  Or remove it from homekit?
Are you following these instructions?
  1. Launch the Arlo Secure App on your Apple device.
  2. Tap Settings > My Devices.
  3. Select an Arlo SmartHub or Arlo Base Station.
  4. Tap HomeKit.
  5. Select the Arlo SmartHub or Arlo Base Station you want to add to Apple Home.
    If you receive an Uncertified Accessory Error message, visit: When adding my Arlo Base Station to Apple Home, what should I do if I receive an Uncertified Accesso...
  6. Select a Home or tap Add New Home.
MC3
I am following those instructions
 i am removing the device from my account. I cannot add it to HomeKit bc of the scan/enter setup code issue. That happens after the steps you’ve shown me below. I follow those instructions, select a home, room, and then it alls for a setup code. I cannot bypass it.
