Setting up a reset system in new location. VMB3000 What am I missing?
  • 4 Replies
  • 4705 Views
jcweller1
I'm setting my oroiginal unit after removing the existing cameras and base station from my account. I'm at a different location with a different netgear router. Arlo can't find my base station. I have tried a reset on the base station. Nothing I try works. What am I missing?
I can log into my account and try to setup new devise and that won't work either.
Do you have booth the power and Internet LEDs green?  Are you using the all or browser? If the app, are you on the same network as the base?
jcweller1
Good morning.
Yes I have both the power and internet lights on. I have tried the APP and
the PC. The base station shows up on the network on the iPhone APP but not
the PC.
Thanks in advance
PC antivirus software can interfere, especially BitDefender. If you're using BT, search here for solutions. If not, try temporarily disabling any antivirus/malware software for the purpose of initial setup.
jcweller1
I disabled Norton antivirus. No Bitdefender. Still can't make the system work.
I believe there is an issue with the base station.
I'm done with these Arlo camera systems now. Too many battery problems and issues with
syncing. I have replaced with the Blink Home Security System. Better pricing and a far better
system for much less money with a one year guarantee that the batteries won't die. And
the batteries are rechargable with a USB port on the camera.
