Setting up a reset system in new location. VMB3000 What am I missing?
I'm setting my oroiginal unit after removing the existing cameras and base station from my account. I'm at a different location with a different netgear router. Arlo can't find my base station. I have tried a reset on the base station. Nothing I try works. What am I missing?
I can log into my account and try to setup new devise and that won't work either.
Do you have booth the power and Internet LEDs green? Are you using the all or browser? If the app, are you on the same network as the base?
jguerdat wrote:Do you have booth the power and Internet LEDs green? Are you using the all or browser? If the app, are you on the same network as the base?
I disabled Norton antivirus. No Bitdefender. Still can't make the system work.
I believe there is an issue with the base station.
I'm done with these Arlo camera systems now. Too many battery problems and issues with
syncing. I have replaced with the Blink Home Security System. Better pricing and a far better
system for much less money with a one year guarantee that the batteries won't die. And
the batteries are rechargable with a USB port on the camera.
