One of my cameras is too sensitive, recording leaves dropping from trees or bushes moving from heavy breezes. I currently have it set at 80 so want to, uh, de-sensitize it down to 50 or 40. I am fine in navigating to the camera, armed, and the editing template for the camera. HOWEVER, after I move the slider downward from 80 to 50 or 40 or wherever, I can see or find no "SAVE" button to make the changes stick. I've tried going directly to "Log Out," but when I return, the slider has reverted back to 80.
Would anybody have some advice as to how I can make the sensitivity stay where I'd like? Thanks.
R_Lowe,
After making changes, click "Back" and then "Save" will be located at the bottom of the screen.
Take a look here for more detailed instructions: How do I adjust motion and sound sensitivity?
R_Lowe,
Beautiful; it worked -- thank you so much!
Mike
That implies that you need to reposition/angle the camera. Post a screenshot.
