Two of my arlo cameras got water inside the battery compartment and rusted out the batteries causing them to malfunction. I have tried to clean the terminals with wire brush to remove the rust, but they no longer work. Anyone else having this issue with the cameras? I"m not sure if this is something that has been fixed with newer models, but I would like to know before trying to replace them. I love the cameras, but I'm now down to only 2 from my original 4.
How old are these? You have at least a 1 year warranty which you can use by opening a case with support here.
The Pro series use a rechargeable cube and a totally different connection mechanism. If you're looking a new cameras, I'd definitely go with any Pro-series camera.
oakes5204,
These cameras are designed to be weather-proof. As long as the battery compartment door is closed properly, water/moisture should not be able to enter the battery compartment.
