Restart
A factory reset is below, but you may not have to do it....
First I would just POWER down the base ( via power button ) and restart.
If not fixed, AND SINCE you modified a mode, you prob just have to add the email back.
Go into the Rules for the camera in question and make sure the email list is there under "send email to this list"
If you change anything don't forget to SAVE on exit
Then go to the MODE you prev changed and make sure the RULE you just looked at is active ( check is green ).
Test it again.
- Perform a factory reset on your base station.
Push the Reset button (on the back of the base station) and the Sync button (on the side of the base station) for about 10 seconds or until all the LED lights on the base station blink amber. This procedure returns the base station to its factory settings. If your cameras were synced to the base station, you might need to sync the cameras again after the base station comes back online. For more information, see How Do I Set Up And Sync My Arlo Cameras?.
Hello AlexP,
If you're not receiving any notifications or media in your library, your base station may be offline. Another possibility is that If at anytime you have deactivated the base station and/or performed a factory reset you will need to re-associate your base station with your Arlo account.
Can you confirm if your base station is online and connected to your Arlo account? Please also confirm Power, Internet, Camera icons show solid green LEDs on the base station. Are able to live stream your cameras. If you're able to do these things then be sure your motion detection mode is enabled.
If none of these suggestions help we may want to open a support case to continue troubleshooting this issue.
Best Regards,
Christine
Arlo Team
____
Please click
KUDOS or REPLY if you found this helpful.
You didn't say that your phone is on your WiFi - is it? Try a computer browser. For the reset, did you use the proper method, using only the reset button until the LEDs flash amber?
@JamesC, does the base need to be deactivated in order to install in a new account? Would the lack of deactivation cause this?
Marky10, jguerdat
When transferring a system from one account to another, the only thing that needs to be completed for the new user before they can claim the base station is a factory reset.
A factory reset can be done manually (pressing and holding the reset button) or by removing the base from the account.
Marky10 indicates a factory reset has been performed manually, so this should be enough to allow the base to be added to a new account.
One piece of information that we do not have is the LED behavior on the base station. If everything is behaving as expected, we should have a solid green power and internet LED about two minutes following the factory reset. I would advise completing a factory reset again (hold the reset button until all LEDs flash amber) and allow the base station to come back online with a solid green power/internet LED and attempt setup again.
