Changed Internet provider Arlo won't work since moving
Hi, I had arlo working well with my my last internet provider but due to moving house I cannot get the sytem to reconnect to my new service provider. Any ideas? TIA
It should have been seamless. What are the base LEDs showing?
All Light are one all Green. I have tryed resetting the Base Station but The Computer cannot find it now.
Not sure what you mean by this. You should have at least 2 green LEDs, power and Internet, especially after a reset. Speaking of the reset, did you use the proper method, using the reset button alone until the LEDs flash amber? It may be you have a bad base that can only be resolved by contacting support, using the Support link above.
Daniel87,
There could also be a conflict between the new ISP equipment and the Arlo system. I agree with jguerdat and recommend contacting the Arlo Support Team for more in depth troubleshooting.
