I am having issues with 1 camera I have opened and closed the camera moved the batteries and still a pink and red picture what else can i do??
Brewyc, cad26
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
I have the same issue. My camera is only a year old.
what can be done/ I hope netgear honors this and it seems like its a big problem
Brewyc, cad26
This is ridiculous that no one from support can put the solution public or what!? Mine was working perfectly fine, with a crisp clear image until I had to replace the batteries. Once I replaced them and placed camera back in position, it had a pink red tint to the view.
The solution has been made public a million times here - contact support. That's the only way you'll get a replacement camera. We certainly can't do that here.
Read my previous reply two messages above yours.
Just read the replies in this and many other threads..
maspeik wrote:
Camera displaying red/pink. What are my options for clearing resolution?? Tried open close/replaced batteries. Same indications. HELP !!
Did that - no change
Annmarie,
Use your case number and send your own update to ask for status.
New System. Installed two cameras then added three a week later. One of the originals working fine turned pink like a blue filter went out
Nevillemcv,
