  • 10 Replies
  • 4902 Views
D8675309
So I bought 2 cameras and a base station with two inputs for USB. Thinking both cameras would record. I understand now only one camera can record at a time. Is the best solution a second base station for the second camera?
10 REPLIES 10
The original base can't use the USB ports. However, ANY of the bases support multiple cameras recording at the same time to the cloud.
Also, the bases with a USB port will back up the recordings from all the cameras to a single USB drive.  You don't use one USB drive per camera.
If you can't get two recordings at the same time, then something is wrong.  How fast is your internet upload speed?  If you aren't sure, check it with speedtest.net.
D8675309
D8675309
But only one camera is recording. Internet speed is good
Are you sure you have the right base selected? This sounds like it's a VMB4000 which has 2 USB ports, both of which can be selected.
D8675309
Yes. I apologize. You are correct. So how do I get both cameras
To record ?
D8675309
I know I seem like an idiot lol
But I’ve gone through the manual. I’ve gone through all of the troubleshooting articles. I can’t find anything as to why the second camera isn’t recording
ShayneS
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
D8675309
Thank you very much. I will do that
ShayneS
@D8675309
You are welcome. Please let me know if you have any other questions. I will be happy to assist you.
