Rechargeable Batteries
I believe I found the answer to using rechargeable batteries. I'm about to invest in Tenergy batteries and a charger. Supplying 4 batteries in my 4 cameras is getting costly at $42 for 14 Duracells and the batteries drain way to soon for being turned off most of the time. I'm trying to follow that reason and possible corrective actions.
Another question is firmware updates. My station shows I have version 1.12.2.1_2798 Is this the current version? I thought it would update automatically but I haven't ever seen any notifications of any updates. If not the correct version, please tell me how I get it downloaded and installed.
Thanks in advance
Larry T.
I use Tenergys. They may last a little shorter but then you can recharge them.
When you say your cameras are off most of the time do you mean that they are not recording any motion or that you have the base turned off?
According to https://community.arlo.com/t5/Firmware-Release-Notes/bd-p/arlo-release-notes you have the latest firmware on your base which all being well should either update on its own or prompt you to update.
Thanks Streaker2 for that information. I have never turned the base unit off. I turn the cameras off when not in use which is most of the time and the batteries still drain but not as fast. I am going to order the Teneragy batteries and charger. Non-rechargable batteries are way to costly.
Thanks for the idea but for now will probably stay with the PRO. I bought the unit with 4 cameras christmas of 2017 from Home Shopping Network or one of those shows for a really good price. Not knowing the battery issue. I don't really use the cameras all the time as I'm retired and home a lot more. I only mounted two cameras by entry doors so hopefully getting rechargeable batteries for two units will be enough. I don't need to get too techy at my age.
