Rechargeable Batteries
Whats the highest mah we can use for the arlo wireless camera?
There are only the Tenergy batteries that are certified by Netgear. Anything else is up to your own discretion. I have some Ultrafire batteries that are 880mAH and I reckon that's probably about right but anything more than that, I suspect are cheap Chinese fakes. I doubt you can really get 1500-2500mAH into a CR123A battery. Beware of buying batteries from eBay
Thanks for the info. I figured the same thing but i wasn’t sure of it..
as above;
you physically just can't get more than about 750mahr of chemicals in a 123 sized object
Early on I used some cheap 2000+mAH batteries. As we learned things, they went into Home Depot's recycle bin. No sense in taking chances.
