Rechargeable Batteries
  • 4 Replies
  • 2782 Views
RussellD120
Whats the highest mah we can use for the arlo wireless camera?
steve_t
Master Master
There are only the Tenergy batteries that are certified by Netgear. Anything else is up to your own discretion. I have some Ultrafire batteries that are 880mAH and I reckon that's probably about right but anything more than that, I suspect are cheap Chinese fakes. I doubt you can really get 1500-2500mAH into a CR123A battery. Beware of buying batteries from eBay
RussellD120
Thanks for the info. I figured the same thing but i wasn’t sure of it..
as above;
you physically just can't get more than about 750mahr of chemicals in a 123 sized object
Early on I used some cheap 2000+mAH batteries. As we learned things, they went into Home Depot's recycle bin. No sense in taking chances.
