Receiving motion notification but unable to view in library on iPad and iPhone
for about 2 weeks now on recieving motion notification and going to view in library the file disapears so your unable to view it. I have restarted device check connections etc as still no fix. Viewing from ipad or iphone has the same issue.
Any idea or wait for update?
Are you sure you don't have any filters set to a different camera in the Library? Also check to see if a firmware upgrade changed your settings. I would power cycle the base and see i that clears things up.
Brian
