Receiving motion notification but unable to view in library on iPad and iPhone
  • 1 Reply
  • 1280 Views
LaraCroft835
for about 2 weeks now on recieving motion notification and going to view in library the file disapears so your unable to view it. I have restarted device check connections etc as still no fix. Viewing from ipad or iphone has the same issue.
Any idea or wait for update?
brh
@LaraCroft835,
Are you sure you don't have any filters set to a different camera in the Library? Also check to see if a firmware upgrade changed your settings. I would power cycle the base and see i that clears things up.
Brian
