Had a camera get the dreaded red tint. Steps from chat support as follows:
1) Remove batteries
2) Unplug base station power cord
3) Wait 3 minutes
4) Put batteries back in camera
5) Plug base station in
6) Wait for green status indicators for power, internet connection and devices
7) Hold sync button on base station for 3 seconds
😎 Hold sync button on camera for 3 seconds
9) Log out of Arlo app
10) Log back into Arlo app
11) Check camera video. Mine finally started working properly again.
Of note, the FAQ page only mentions removing the batteries then putting them back in. That seems to be a soft reset, which sometimes solves the problem. The 11-step process seems to be a full reboot of the camera.
I'm rocking the Arlo Wire-Free system.
Cheers,
KELSO
FYI, the pink issue is the IR filter stuck in place.... other than reset of the camera ( pull batteries ) not much else will do the trick.... it is a mechanical issue not sw.
Other solutions are 1) gently tapping the camera on hard surface 2) some have mentioned a magnet on side of camera
Some times it takes multi resets to free the stuck filter...if it happens again, and cam is less than a yr old, look into warranty
