Outside cam has weird orange color light
  • 2 Replies
  • 2748 Views
Barbara444
My outside camera Shows a weird golden colored light when it is normal daylight outside. Have I somehow set it to do this? I don’t know how to fix it.
steve_t
Master Master
Is it pink-ish?
Try opening the battery cover and then closing it again to restart the camera. If that doesn't work, contact support as you probably have the all-too-common stuck IR filter and they should replace the camera for you
steve_t
Master Master
Is it pink-ish?
Barbara444
Fixed! Thanks!!
