I noticed that briefly when I brought a camera in and then replaced it outside. It was just moisture on the lens and went away on its own. You might want to wipe the various lenses to clean them and maybe use something like Rain-X to try to prevent future issues.
Also check and make sure the small oring is in place ( under battery door ) ...
I wiped my o-ring with a very small amount of silicon grease ( used on cameras, etc ) or silicon spray ( spray on finger and wipe the o-ring , not into camera )
PS ;NOT silicon sealant
It was as basic as that, many thanks.
