  • 12627 Views
  • 2 Likes
Roobydoo
Recently my outdoor cameras are producing very cloudy videos, the indoors ones are fine. Cameras havent moved and I previously had no problems. I have the latest firmware installed and although I cant say for definite the problems seem to co-incide with that. And no it is not foggy!
I noticed that briefly when I brought a camera in and then replaced it outside.  It was just moisture on the lens and went away on its own.  You might want to wipe the various lenses to clean them and maybe use something like Rain-X to try to prevent future issues.
Also check and make sure the small oring is in place ( under battery door ) ...
I wiped my o-ring with a very small amount of silicon grease ( used on cameras, etc ) or silicon spray ( spray on finger and wipe the o-ring , not into camera )
PS ;NOT silicon sealant
Roobydoo
It was as basic as that, many thanks.
