Tried to resync it a couple of times but it isn't working. Bought a 4 pack system a couple months back and all 4 have been fine. Even yesterday this camera was working and recording fine but when I woke this morning it says it's off line and so I removed it and tried resync but not working. The blue lights blink slow and then fast like it is resyncing but nothing is coming up in the app or on my computer. Any ideas welcome.
Another update another disaster. HEY NETGEAR FIX THIS CRAP NOW. ENOUGH IS ENOUGH. WHEN WILL YOU LEARN THAT YOUR FIRMWARE UPDATES ONLY MAKE THINGS WORSE. PLEASE STOP ADDING INSULT TO INJURY.
Well it was not pretty but I had to get the dman ladder out yet 1 more time and resync all 10 cameras to get them back on line. A few of them did not intially accept the sync the first time so I had to pull the batteries and put them back in and resync again. However there may not be a happy ending here. On a couple of my cameras I have the "RED TRIANGLE OF DEATH". This is the symbol that indicates the camera does not have the most current firmware. Us Arlo veterns know this spells instant doom as the last 2 hours of my climbing up and down ladders will be all for not when I wake up tomorrow and find more cameras off line again because of a firmware update.
Let's be positive.
The cameras may have gone offline due to the recent firmware update not completing, for more information on how to troubleshoot this, see here: My Arlo camera is offline since the release of the recent firmware update; what do I do?
Please let me know if you are still experiencing issues syncing your cameras.
Yep, had the same issue; one of my cameras went "offline". Wasted a ton of time trying to resync the camera. I tried another camera and it didn't work either. Then one of the other previously working cameras went "offline" too.
What I didn't know was they changed the syncing process. You don't hold down the sync button on the router anymore, but just press it quickly until the sync light flashes. If you press the button too long, it simply won't work.
It would have been nice if they gave me some notification of this "upgrade" process ahead of time.
Jtoaster,
If you're experiencing a camera offline issue, consider the troubleshooting steps in this article: My Arlo camera is offline since the release of the recent firmware update; what do I do?
Also, if you would like, provide me the case number you have open with support and I will take a look at your case and provide any feedback that I can.
I tried the troubleshooting to no avail. Today I removed both cameras from the system and tried to re add them as if they were new. One synced and the other did not. However the one that did sync will not follow any of the rules set for it but will display when I click "live". Both cameras are functional as far as turning on and infrared lights coming on upon first activation. The app opens but now only one camera is active the second one wouldn't even sync. My case number is #27484338.
Jtoaster,
Thank you for the case number. It sounds like there could be a separate issue involved. I will take a look at your case and escalate if needed.
New batteries, re synced, powered down and reset the unit, checked and a reseat on the cable and still off line error. I even uninstalled the app and reinstalled it, still I get off line error. Now I can't get my sign in to remember my password. I've had this unit 1 yr and everything was fine until a week ago. Help!
Have been having this issue for weeks and still haven't figured it out. I have re synced cameras which some worked and some didn't. The ones that worked only lasted for a day and went back offline. I changed batteries and tried again. Same thing. I had 3 of 9 cameras working for a few days. I just tried rebooting the base station and now they are all out. At a loss here on what to do. I read the better admin recommendation and have done it twice. Not really wanting to climb a ladder for the 5th time for something that doesn't work. Has anyone got theirs working that hasn't been recommended?
I'm having an issue with what I call the random offline issue of one of my cameras, I'm running firmware 1.2.7730 model H7 . This camera has a mind of its own - it works for 10 days with no problem then I wake up check my camera and it's off line.
The other cameras are fine, in the past I've changed the batteries, resynced the camera and work for a few days then bang off line. It's a security camera for a condo that I'm away from two weeks a month. It's frustrating I'm looking to replace it if it can't be fixed.
For all of these issues above, contact support (there's a link at the bottom here). it may be bad hardware that needs a replacement.
Jug
thanks for the response I followed the link "contact support" it took be back to the same web page that got me to the communities. I did send an email via that page with by Arlo issue, we'll see if anyone gets back to me.
cheers
Not sure what you saw but it should have taken you to https://www.arlo.com/en-us/support/contact.aspx where there are several methods of contacting support as you go down the page.
Birdseye2,
Are the batteries depleted? Open and close the battery compartment door on the camera, what is the LED behavior?
