Settings, Notifications. Set the ringtone. It's a new feature.
With the S7, you have the option to change sound for alerts, vibration , and LED color / with flash rate...
vey nice now as push alerts, I changed to bird chirps
Have you power button reboot the S7?
If NG, remove and reinstall app
Sorry to hear... running the same phone here , no issue
S7 and android 6 (marshmallow )
On my Google Pixel phone when I go into Arlo/Settings/Notifications/Notification Tone I've got 10 tones to choose from. I like "Hey". Catches my attention but makes others wonder
It can be frustrating when it happens... but I have no answer other than those above.
Same phone/os, same sw, and no problem here.
BTW, did no changes to permissions, just went into the settings of the app itself and changed there.
Sounds like you should make a call to Support and ask if they have similar issues
just a thought. Can you set up your account on someone else's phone? If it works ok there, then its something with your phone or its settings.
If same problem, would suggest something about your account (though I don't see how).
The fact that it works for me and many others suggests its not the app.
very ..... i'm out of ideas
Like prev mentioned.. I did nothing but update the app... everything then worked as expected on same phone, same OS...
BTW, what service, I use verizon's network
I'm having the same problem. Tried everything. Nothing works.
Details. What phone/OS? What have you tried?
This is correct.
DO not restore you phone, there is a huge pain. I discover this feature by accient.
Under [Setting], [Notification] sub menu, there is [Notification Tone] selection, change to something other than default, and slide [Vibrate] to off. Problem fixed.
jguerdat wrote:Settings, Notifications. Set the ringtone. It's a new feature.
