New account
  • 5 Replies
  • 8887 Views
  • 5 In Conversation
PieterWH
Hello, just bought the Arlo Netgear. I can't fill in the form where I have fill in the serialnumber. What is going wrong???
Piet
Netherlands.
5 REPLIES 5
DaneA
Hi PieterWH,
The Arlo serial number should automatically be discovered and populate in the "Base Station Serial Number" field. Kindly make sure you are registering the Arlo system while connected to the same LAN network as the base station. Check this link:  How do I enter the Arlo Serial Number?
Kindly answer the questions I have summarize below:
1. What device are you using in registering the Arlo system?  Is it an Android or iOS device?
2. Do you have a wired or wireless router?
3. Is your Arlo base station connected directly to your router?
Regards,
DaneA
Arlo Team
doraemon
Prodigy
Prodigy
hi,
When connecting your Arlo, it is mandatory that the device you use to configure your Arlo should be connected to the network of your router. If you use your phone/ipad/laptop, make sure that it's connected to the wireless network that your router is broadcasting.
gimme dorayaki 😄
Martymar8
Martymar8
I want to renew my account for 7 cameras. It says "go to account settings and click on renew" there is no "renew" in my account settings. Just "account" and it says "basic" everything is grayed out.
Martymar8,
Take a look here for instructions on changing subscriptions: How do I change or cancel my Arlo subscription plan?
Note: This will need to be done using the web client or an Android device.
