Arlo Wire Free Camera no phone Alerts
I was getting alerts on my cellphone when motion was picked up by my Cam's now I have no clue when i get motion. How do i fix it so when there is an alert i recieve it on my phone? thank you
Check your modes in the Mode tab to ensure notifications haven't been turned off. Also check the phone settings for the app to ensure notifications haven't been disabled there. You may need to reinstall the app and restart the phone to see if that helps. If not, what phone and OS?
Nitekate,
What do you mean by "it got hooked to Hotspot data"? When using a mobile device, the app will use either WiFi or the data connection, whichever you have enabled.
If you are not receiving push notification alerts, check your mode/rules to make sure notifications are enabled.
