  • 1 Reply
  • 1008 Views
gla1
Camera 1 is wired doorbell, Camera 6 monitors garage doors from inside. Previously I had Cameras 1 and 6 activated at all times to record motion. Cameras 2-5 were set to only record motion between 7pm and 7pm, usually dark. I can’t find a way to do that now. Is it still possible? Appreciate any help.
Yes, it's certainly possible. However, the answer depends on which user interface (UI) you're using - the old one which uses Library to view videos or the new one that uses Feed.
Generally, you need 2 modes for this along with the schedule. One mode would have all cameras armed (Armed or Arm Away, depending on the UI) and the other that has only 2 camera (1 and 6) listed with rules (either a custom mode or Arm Home, again depending on the UI). You would then schedule the modes at the proper times to take effect.
Let us know which UI you are using so we can go into details.
